Disc Swap gone bad...Parts needed
Arizona - PHX area
Howdy, After 5 months of assembling new and used parts I started front disc swap only to find one donor hub had spun the bearing race and the hub is toast (my bad for not inspecting the Tucson craiglist seller more carefully, I am just too trusting I guess).
Before I look nationally I thought I would start locally,
If you have a wheel hub ( not locking hub the one with bearings) for '86 FJ60 axel or if you have a full axel I may just start over so I get all the parts I need.
Also may need some old steel factory wheels for a disc set up. My back space is only shote .45" , but not sure if I want to use spacers.
Thanks, let me know if you have any questions ( I will buy or trade if you prefer)
Scott
I may have one lying around, let me see what I have here. This is the freewheeling hub the rotor and studs are pressed onto correct?
Does the race just slip into yours, not beat in with a race driver, is that what you mean by bad?
Thanks MC - you are correct, I call it the hub, but it bolts on after the spindle and before the locking hub. Has studs to hold locking hub and houses the bearings. Yes a new race will fit in by hand and will rattle arround and the scoreing is very visable.
THANKS!
I found one!....$30 plus shipping or available for local pick up. I won't be at this meet this month because I'll be wondering around the Caribbean. :)
Done deal! e-mail coming
thanks all.
Scott
