Disable automatic steering wheel retraction?
South Jordan, UT
Hey folks.
After searching, it looks like it is possible to disable the automatic retraction of the telescoping steering wheel. Does anyone know if this is a DIY modification? One reference I saw said that the dealer had to do it.
Do it you yourself with techstream. There's a good thread around here somewhere.
I disabled the auto tilt/telescope and DRL and programmed a couple of keys while I was in there. Pretty easy.
X2
Straight forward with TechStreeam
Is there a definitive thread for getting set up with TechStream? Looks like there are some pitfalls with getting the correct OS, drivers, etc.
I had the same worries but had no problem and I still use a flip phone:flipoff2:
Does this eliminate the irritating motor noise that emanates from the steering column (4X as loud as the air mixer) seemingly every time I start the vehicle...and often every few minutes while driving?
I found what appeared to be the fuse for the tilt/telescope, but that fuse also has SRS duty...so hardly want to pull that bugger!
