Today, I started to change the oil on both diffs and the transfer case. I started with the transfer case, which went well. The old oil was looking really dark, but there was only a thin film of metal on the magnet in the drain plug. No problems on this one......
I started the rear differential next. The fill plug opened easily. The drain plug would not budge. I spent more than a half hour working on it. I sprayed blaster on it a few times and let it sit for a few minutes, but that did not help either. I was unable to open it. From me trying to unscrew the bolt, some of the sharp edges are looking less sharp. What should I do? Other than PB Blaster, I do not know what I can try on such stubborn bolts.
Now the front diff.... I tried opening the fill plug first. I tried to be careful with it, but it slipped right away. There is still some definition of an edge on the fill plug but only toward the end, and it will be very hard to get that out.
That is the trouble I am in. When I finally find a way to open the drain plug on the front diff (the one that slipped right away), I will replace with a new one. Same with the rear drain plug....
That is the problem though now - how to get it out?
Ideas will be appreciated.
BTW, I went with Mobil1 75w-90 synthetic.
