Differential actuator motor magnets has fallen of... (1 Viewer)
Holstebro, Denmark
So I got a bit of an issue. 2 of the 4 magnets has fallen of. 1 on each side of little metal cab.
I am travelling and in Jordan right now.
So I do not have access a new actuator any time soon I want to try and glue the 2 Magnets back on.
But how do I make sure they are glued on the right way.. the shape makes the Magnets have in inside/outside but up/down is not so obvious
You know what I mean?
And yes I know one is also broken but it is worth a try.
Everything worked fine until this morning when the diff lock would disengage.
I was able to take the cap of and manually rotate the little motor until the rod disengaged.
At least now I can drive again.
I figure I will use JB weld to glue them back on.
