Differences in rear door panel 2016-18 vs 19+
JOFS
GOLD Star
Maine
Anyone have any info on the differences in a door panel for rear doors? I have a 17 and found a panel from a 19. But seems there was a change based on toyota parts sites. Don't know if it is a major issue or something small and cosmetic.
My dog messed up my drivers side rear door panel and want to replace it but it is about 1K new. Found a used one but from a 19 and it is much cheaper. Pictures look the same but don't want to buy if it is dramatically different. DIdn't know if anyone has knowledge of this.
Thanks for any info.
John
Digging into the parts diagrams it's not encouraging. Toyota did make some changes in 2018 including wiring and that appears to apply to the 2019 door panel as even when the trim colors are the same it seems the part numbers aren't.
If the cost is low enough it still may be worth the risk.. the door card comes as an assembly and they would have used a different number even if one small part changed. A lot of this stuff is modular and you could easily move over your window switch, tweeter, etc.. I'm assuming all that stuff on yours is still good.
There are a whole bunch or LC200's on the wreaker Auction .. so likely a lot of parts available used soon.
I even saw the 2 that someone posted .. "that last picture of my 2 LC200's." as they put the Lexis in the garage.
