Diagnosing OME rear shock squeak
2000cruiser
Pismo Beach, San Francisco, Seattle
I have a single OME rear nitro shock squeak that's driving me nuts. All other corners sound fine except for the rear driver side. It's extra sensitive and the slightest movement triggers the sound. How can I tell if it's the shock bushings or internals of the shock or something else near the area?
Standard 2.5 OME lift, heavy front, medium rear.
Thanks in advance
Thanks @enox - I just drenched the bottom bushing with some silicon. Still a bit a squeak when I bounce the rear end, but I will let it soak in, add more and move on to other shock bushings if needed.
Well, it looks like it’s the rear driver springs. Even the lightest touch makes it squeak.
Did you ever figure out what was causing the squeak. I have the same thing and it seems to be coming from the top of the OME rear shock. Solution?
Unfortunately I never figured it out- ended up replacing my entire setup a few months after. If I ended up keeping the OME setup, I would have checked the bushing and washers. Drenching them with lubricant didn’t stop the sound.
