SOLD Denver - M416 Expedition ready with RTT, Awnings, Propane, and more! SOLD TO A TOYOTA GUY!
M416 Expedition Trailer fully loaded
$6,500
Aurora, CO
M416 Expedition Trailer for sale
Just finished last year and only used for 5 nights.
Jeep grill on back is a sticker and can easily be removed for all you non-Jeep guys.
Clear Title
Set up to carry two kayaks and canoe. Extended tongue makes it easier to tow and back up, plus it made room for dual Optima batteries in box. Battery box has room for some storage on top and contains a fuse system, 2,000-watt inverter, and waterproof 120/12v/USB outlets on the front. Stock hand brake has been moved and works great. All LED running lights, rear tail lights are clear with red stop and turn on them. Accent blue LED lights around trailer and in bed. Regular fog lights on top. New tires, hubs, springs, and original spare mounted on tongue. Entire tub was sandblasted and then POR15 with UV protected bed liner put over the top. Tons of room inside for waterproof storage! Dual propane tanks for all your camping needs and a never used propane water heater for showers. Has one 5-gallon water tank and one 5-gallon gas tank mounted on front. Has landing legs in back for complete stability when camping. Also has on board ladder tucked up under deck.
Trailer does great on the freeway. Drove it from Virginia to Colorado without a problem. It has the pintle hook mount that allows for complete articulation and is actually quiet due to weight of trailer. Is set up with 4 pin trailer lights. I will include an adjustable receiver hitch that goes into a 2" hitch with pintle so you can hook up and go. Off-road on fire trails it does awesome as well. Only reason I am selling is because I have another project I need the cash and room.
This is basically a brand-new unit that has been tested and used for only 5 nights.
Asking $6,500 OBO - Cash talks
Included:
Very clean M416 Trailer $2,500
Custom Aluminum Top $500
Sand Blast trailer/POR 15 entire trailer/UV protected Bed liner $1,000
New Tires/Wheels/Hubs/Springs $1,000
Custom rack/extended tongue/hitch/side skirts $2,000
Battery box/2 Optima's/wiring/converter/Optima brand charger $850
Tepui Ruggedized RTT $3,000
2 ARB Awnings $500
Two propane tank/mounts $250
Prop hot water heater/never used $100
Water and Gas tanks and mounts $150
VIN and Title $200
LED lighting $200
Adjustable pintle hook and adapter $250
2,000 watt inverter (not shown in pics) $200
Total $13,000 without labor
More Pictures can be found here - M416 Expedition Jeep Trailer
amazing build! 6 months earlier and i would have grabbed this in an instant. Found a slightly less built out m416 in LA.
I am out of town on work, but if I remember correctly the bottom of the RTT sits at 73 or 74" as I wanted to be able to walk under it and fully extend out the awning room and that was the height Tepui suggested. I believe the top of the tent when closed is another 10 or 12". This could easily be adapted with actuators to lower for travel if you were not planning on bringing kayaks or canoes. It clears my 8' garage door with a few inches to spare.
Pending sale
Sold! And to a Toyota guy! He had not heard of this site so I gave him your info. Enjoyed hanging out with you guys in the trailer section over the past 8 years building different trailers. Thanks for being nice to a Jeep guy while I was here. Good luck to everyone! Moving to a 4X4 motor home of some sorts so I can tow my trail rig.
