I had no idea the oil was that critical. Not that I have read up too much on the Toyota diesel motors. Not calling BS, but doesn't seem to lend itself to bulletproof longevity if you have to have such specialized oil. How do people outside Japan source their oil? Does someone in the Middle East or South America import oil from Japan just for thier diesel powered Toyotas? Just curious, not trying to start anything, I am genuinely curious, that is just how my brain works. Sorry.
No common rail injection for me, I have a 7.3l International motor, so it uses the HEUI injection system. Essentially there is a high pressure oil pump that drives the injectors. That is why the oil change interval (at 15 quarts) is so often on a PSD vs. 10-15k on a Cummins. The oil gets worked very hard, it not only lubes the motor but it gets pushed to 2500lbs to fire the injectors.
Jack
OK, the main reason is the original big end bearings installed on these motors would fail after a relatively short time, quite often catastrophically. These motors all need to have the original bearings replaced with aftermarket bearings, and that issue goes away. even a couple of instances on the FT motors too.
This became such a big problem in OZ with the 1HD-T engine that toyota, after much pressure, reluctantly agreed to a "silent recall" similiar to the one that was forced onto them here in the US regarding the failure of the 3.0 L V6 head gaskets
The beb were made of some funky alloy that was unique to these engines, turned out to be a bad idea, prone to flaking and de-lamination of the bearing surface down to the substrate and eventually failing, usually at speed under load with no warning.
The problem was not as bad in japan as other places, reason being the japanese spec oil was different. the oil sold in OZ and EU had different additives that didn't protect these particular engines as well as the japanese oil.
Also, there are some differences in diesel engine design, US vs European vs Japan. things like piston dome thickenss that affects transfer of heat through the piston to the oil. Things like clearance from piston to cylinder, above the top ring.
I'd been reading about the BEB failures for years when I bought my truck. First thing I asked the PO was if he'd changed the bearings. No. But he'd run AMSOIL it's entire life. when I bought the truck, engine had around 300K miles on it. These things had been often failing at under 100K miles. I didnt know about the amsoil being good for the engine at that time, so I was plenty worried on the drive home. I parked it until I got the parts in hand. Yanked the pan, pulled the bearings, they were all fine except number 6 which had the very first signs of failure. They could have gone another 100K probably before they went. full on factory-new spec compression numbers as well The rest of the engine looked new inside, so I was pretty impressed. I attributed it to the oil.
It was shortly afterward that I ran into a guy on one of the diesel lists, lives in NZ. He is a "tribologist" and had studied this issue extensively as it regards these 1H series engines. He sent me links to publications explaining the differences in engine construction and the differences in lubrication requirements for each. It's quite a long read, believe me.
That's the very very short story.
