I sure am appreciative of the education I've gotten here. Thanks in advance if there's more to come.
A month ago I took my new-to-me '03 LC to a dealer in Seattle for some baselining and other stuff. The car had always pulled a little - just enough to be noticeable - to the right so I told them about the problem and requested an alignment to cure it.
This dealer does not do service loaners but if your repair exceeds a certain dollar amount (which mine did) they will rent you a car from their in-house Avis (or whatever) and pick up the tab. I work at a job where I need a car on short notice and it's seriously inconvenient to have someone pick me up, take a cab etc. to and from the dealer.
When I picked it up I still felt it pulled to the right, about the same as it had before. To make sure I wasn't crazy I drove it some more and had other people drive it. They all said they felt it pull to the right and I hadn't said anything about it to them so figured I wasn't nuts. Granted, I didn't call back for a month but I really wanted to make sure I wasn't imagining things.
Today I called the dealer service "team leader" who basically said they'd stand behind the alignment but I need to leave the car with them again for at least half a day so they can see if it's 'something else' and since they don't know what it is he won't pick up the cost of the rental for me again.
My feeling is that if they did an alignment to solve a specific issue they should have road-tested the results and if they had they would have known it was still pulling and would have either re-done the alignment or investigated further while they had the car and I had the rental. They could have called and said "we need to fix XXXX" and it will cost $XXXX and you can pick it up on XXXXday" which would have been fine. I just want the goddam thing to go straight down the road without having to correct the direction all the time. I did tell them specifically why I wanted the alignment, they didn't suggest it could be anything else causing it and the problem wasn't fixed.
So, do I puff up my chest and tell them they should have caught this before and need to pick up the car rental for me or did I screw up and therefore should absorb the extra cost? If they won't play ball what do I do then? There is another dealer nearby.
I should say that working with dealer service is new to me. I have a nearly 30 year relationship with my indy shop for my other cars and it's a VERY different vibe. If it were them there's be no questions asked. Of course they know me and know I don't screw around with anyone. I'm not a wrench but I'm not completely ignorant either.
HALP!
HALP!
