Day trip (eagle ridge) 13 or 14
glad to hear you two are OK marcin. sorry to hear about your roll. ICBC covered me, of course they deemed it 100% my fault. since i was a roadstar for 16+ years, i went from 53% discount to either 50 or 43. not much of a ding regardless. hopefully it wasnt damaged enough for them to write it off...although we all know how much icbc loves rhd's.
now, at the risk of being insensitive, lets see some pics!
Since Marcin "came out of the closet" about his truck, here it is:
The trip:
the morning started off well with most of the people rolling in around 9am to the Starbucks for a fix of coffee and getting to know some new faces. I'm horrible with names and was too lazy/not awake to actually write everything down. Truck wise we had a great turn out with 2 40s, 2 60s, 2 80s, a 70, a nice Hilux, a 4Runner (used to belong to the owner of NSOR), a sammy and a Bronco, 12 trucks in all. We headed out at 9:30 and hit the trail where we aired down while trying not to freeze our fingers off. With everyone ready and trying not to get frost bite we hit the now frozen muddy area in full force....for about 50'. The Bronco spun a tire on a small obstacle and was not only out of commission but blocking everything. Luckily it was repairable and we jacked the truck up using a Jack-all and a log and managed to get the tire back on the rim, putting in back on the truck was much harder as we could get the truck safely higher due to it's position, at least using a Jack all. Marcin came to the rescue with his way too cool exhaust jack (which all the guys want for Christmas now, along with ether). Back on the road and through the trees with no other mishaps, once we got to the other side of the gate and hit pavement we found a couple more trucks that were going no further due to the uphill ice rink in front of them. After some attempts, half the guys (including me) sliding on their asses down hill (there is video) we managed to get up there. Back on the trail and mostly doing good, for 12 trucks in different conditions we were moving not bad, my friends Jad and Chris in the open diff 4Runner had some issues and the winch got used before the truck went over the cliff. During this we all learnt the true use of "the Club", a stubborn starter repair tool. We took the hight trail at what shall now and forever be known as Marcin's turn (story a bit further down), the snow and ice making the trail more interesting then usual combined with a couple fallen trees and my chainsaw made it last a bit longer then normal. We got to the rock section before the clearing and other then Steve's 60 nobody went higher, Garry (Squamish) tried but it wasn't worth it. So we decided to find neat ways of turning around and slowly head back. At this time I was now at the back of the pack & I hear that Marcin had a horrible accident and the truck is on it's side, luckily Marcin and Ania are physically good. Down the hill we go to see how we can help, the situation looked bad at first. Marcin's 80 was laying on it's right side with some oil already pouring out onto the ground. Since I missed the action I'll let other's tell the story of what happened there. Most important was that Marcin and Ania were ok other then being a bit shaken up. Now the rescue operation starts, Jason was in front and got the winch ready, snatch block, tree saver and we were hooked onto the newly installed sliders on the 80. Steve's 40 and Martin's 40 behind were both strapped to the back of the 80 so once it's upright it doesn't roll. The pain with this situation was that the truck was down hill, once righted on it's wheels it was against a rocky hill so it would instantly tip again. The original idea was to get rubber on the ground and pull back but that failed. So we hooked up Martin's winch, snatch block and got rid of Jason's and tried going forward. I got inside the truck to steer while Marcin, Garry and Steve used a jack-all to lift a corner so I could turn the wheels, then we got Jason on the winch again to help persuade the front to shift off the rock face. Step by little step we finally got it and managed to, for the first time in this situation, get gravity to work for us. At last the truck was on solid ground and safe. After an oil clean up and top off she started beautifully and we managed to get going again. In total it took about 2 stress filled hours to get everything done. Everyone did an awesome job of turning a very bad situation into something that worked out fairly smoothly. The rest of the way down was easy but everyone's nerves were wound tight so we took it easy. Most headed home some of us went to the Spike for a well deserved hot meal and beers.
Even though we were on a short, very local trip things went wrong. Many days we match machine and man against nature, this time nature won, but we all got home with no injuries, other then bruised egos. The 80's damage is mostly cosmetic and should be easy(ish) to fix.
Marcin, very sorry to hear, but glad all are okay. Trucks are things.
Sounds like ya'll did a great job banding together to make down with no further issues.
gb
what at -10, try -39 with -45 windchill, you southerners make me laugh:flipoff2::hillbilly:
Sorry to hear Marcin, good luck with the fix up, remember if it doesn't kill you, it only makes you stronger!
Cheers,
Deny
Thanks for the write-up Matt. I was imagining worse; although, it sounds like it could have been worse. Glad it is just cosmetic damage. A bit of hammering and some skim coat and Martin's truck will be as good as new. The trails up there do have the uncanny knack of leaving there mark - even if they are right next to the city.
Marcin,
I'm glad to hear you and Ania are both okay. Sounds like things could have been much worse.
That was not quite how I imagined the new sliders would get broken in!
-Jason
Okay, we got one pic of Marcin's poor Cruiser and one vid of a Bronco doing some heavy obstacle work :meh: and Matt falling down sober :lol:. Now where are the rest of the pics for us web wheelers? :D
Fixed for ya!
GG
Interesting run for sure. Very slow going for the distance covered. A bunch of mechanical difficulties. Slippery going as Mat demonstrated especially tough for the open diff trucks. Some winching required.
I think I may have jinxed Marcin when I casually said hope you don't rub the right side of your truck as we were talking over coffee about how he couldn't put on the right slider :whoops:.
lots of traction and clearance was needed for the last few hundred feet of the hill climb.
Mat was kind enough to remove the fallen trees so I could make it to the top of the hill. I didn't want to go much further because no one else was able to rescue me if I got stuck.
Thanks for bringing the chainsaw!
