For Sale Davis Unified Distributor D.U.I with live wires
Northeast Georgia (Habersham)
I had this in my 1987 FJ60. It has been on there since 2006, however it has only been used for maybe 2000 miles. It will need to be serviced. It ran and worked fine, however ACC recommended for expedition type of stuff to have a stock Toyota distributor in case something happened. They also said they had light corrosion on the inside. I opted to go Toyota.
Since it needs a good cleaning I’ll go
$75 plus shipping
I'm still in under one condition and maybe you guys know the answer. Will a 60 distributor fit a 62? If so I'm in. If not I'm out. Need one for the wife's 62.
I have a DUI in my 40. Investigated buying another for my 62 but was told by a tech rep at Performance Distributors that they're engineered to work with F and 2F engines, but not a 3FE. This was a couple of years ago, so possibly the applications have changed.
I'm not saying it won't work on a 3FE. I'm certainly no expert, just repeating what the factory tech said. You may be able to make it work.
This is from Performance Distributors web site.
Toyota Landcruiser F and 2F owners, get charged with a D.U.I.! NO, not that D.U.I. but the Performance Distributors DUI (Davis Unified Ignition)! Installing our DUI into the F or 2F engine means you will be “Driving Under the Influence” of “MORE POWER!” This is the original one-wire ignition system for the Toyota inline 6 cylinder. Built from high quality components, the DUI is the most powerful and reliable stand alone distributor available for the Landcruisers. Our high voltage coil, located inside the distributor cap, produces a spark strong enough to fire a massive .055″ plug gap! The internal high dwell module provides longer spark duration for a crisper, smoother running engine. The mechanical advance assembly is a true Performance Distributors specialty. We use a high performance weight and spring assembly engineered for super smooth operation. The advance assembly is tuned using a Sun distributor machine to ensure a precise timing curve that will provide maximum power throughout the RPM range while eliminating engine damaging detonation. An adjustment free vacuum advance is selected to work with the centrifugal advance for better drivability and increased fuel mileage. Along with more horsepower and torque, additional benefits include quicker starting and smoother idle. The Landcruiser DUI is also designed to be virtually waterproof, making it ideal for off-road conditions. With the internal electronics protected, the DUI will continue to run when other ignition systems fail after being exposed to the off-road elements. Although the DUI is uniquely designed, replacement parts are easy to find. GM HEI replacement parts will fit right on the DUI and these parts can be found at your local auto parts store. Don’t be fooled by the cheap imitation one wire distributors that are available, the DUI is unsurpassed in quality and is the original one-piece ignition system for Landcruisers! The Toyota Landcruiser DUI is covered by a one year warranty from date of purchase.
Fits 68 – 87 Toyota F and 2F engines.
