You need to measure the piston/bore size of the wheel cylinders in both units to make a determination if they are the same, or even close. Also factor in the distance the pistons travel, etc etc. Its all about moving fluid, which translates the pressure exerted by your foot, assited by the vacuum to the brake shoes or pads. Take for example a large piston area on the master cylinder side and a small piston area on the wheel cylinder side: Easy to move, but may explode the wheel cylinder due to the amount of fluid being moved. Sawp it around and you may not move the fluid with enough force to stop the vehicle. Be very careful when screwing with brake stuff!!!! Also a question: If youre using Dana 60 in the rear, is it 8 lug ,and how are you dealing with the 6 lug Toy in the front. I looked into it and could never find a 6 to 8 or 8 to 6 adapter, and never found a 6 lug 60...Very interested to hear.
