D60/14 bolt corp diff cover bolt size
Sudbury Ontario Canada
Im looking for the specs for the bolts that hold the stock differential covers on. Id need the size, thread pitch, and length. If I had access to the damn van Id just remove one of each and head to the bolt place but since I cant.....
Axles are from an early 80's chevy 1 ton.
Also, if anyone has installed aftermarket covers, ruff stuff in particular (flange is just under 3/8" thick), did you need longer bolts?
Thanks
D
3/8 NC If I am not mistaken. Your length will vary if you are mounting brake pumbing etc.
