I am pulling the cylinder head off my '82 2F in order to get the corroded in plugs removed from where the injection nozzles should reside. While it is off I plan to have the following done:
1. Hot tanked
2. Magnafluxed (to check for cracked head)
3. Decked
4. Valve Stem Seals replaced
5. Weep Hole Plug removed, tapped, and threaded plug installed.
I figure I am going to need the following:
1. OEM Exhaust Manifold (only one since the manifolds will also have been decked)
2. OEM Exhaust Donut Gasket
3. Valve Cover Gasket (Aftermarket due to emergency need)
4. OEM Valve Cover Seals
5. OEM Valve Stem Seals
6. OEM Water Outlet Gasket
Am I missing anything?
Should I consider any other work while it is apart?
I want to make sure I get this right the first time.
How many Valve Stem Gaskets are needed? 12? As a reference, I looked at SOR and they show two sizes available, steel and large steel type. Which is the correct one for me to order from Cdan?
Do I need to drain the block of coolant when removing the cylinder head or only the radiator?
And one more, will I need to adjust the valves once it is reassembled?
Thanks,
Tom
1. Hot tanked
3. Decked
Thanks,
Tom
