CUSTOM BUMPERS FOR SALE
Always so pretty when new! - and don't forget my steekers!
BTW: need to touchup sliders on my wagon, what paint do you use? May as well consolidate to one color :)
W, Your covered on stickers.. I use a Sherwin Williams Macropoxy.. Air spray.. but the VHT Satin black epoxy is a perfect match and bonds great.
http://www.amazon.com/VHT-SP652-Sat...id=1445301472&sr=8-1&keywords=vht+epoxy+paint
Most auto parts stores have this on the shelf for about the same $$. The ABS sheet is about 11" x 12", that a good size for you.
Jason
more than enough, even with mistakes...gracias :)
Yes sir and the 70 bumpers are on the truck headed to you and @elkaholic, just picked up.
Jason
Do you weld the support gussets on the ladder? And is that my roof rack there too? :)
You'll need to do the gussets, as the angle needs to be where you want it placed. I can guesstimate it, but prefer not to.I had them there to make sure the height was correct.
No that is the INTI clone rack I'm working on.
J
Jason just send the 60 one to me I want it so bad!
Here it is ready for primer and paint. This will be Goss' last modeling session... His bumper and then off to the new owner, hopefully.
I got started on the 1/4 sliders for @jfnall and some stainless awning plates...
I have to shake out my steel order..I hate when I don't order for a few weeks... PITA... 5 racks to build starting next week and metal for R&D...
Jason
Disclaimer: the booger welds on the light mounting plates, zip tie tabs, and Plug bracket are mine.
I couldn't get the lights squared up in the hole so I changed the bracket mount to a flat plate and squared up the opening after it was tacked in.
HA! if it works man... no judgement here. I ought some of those clips but neither order ever arrived. Not sure what happened, the seller finally just refunded my $
J
Hmm, Ive never had an issue with them (TMR Customs) but have only bought a few things. I have a lot left over I can send you with the other parts we've discussed. With your connections, you'd probably be better off having a sheet laser cut yourself. They are handy for keeping wires up and tangle free.
