'91 toyota pickup, single cab, 4x4, 5 speed with ~170,000 miles (~8,000 of the miles after the engine was rebuilt) and the following:
Here is a list of modifications completed within the last 10,000 miles:
New CV joints,ball joints etc.
new brakes
new belts
new hoses
new plugs
new plug wires
new cap & rotor
new thermostat
new O2 sensor
new knock sensor
new KYB shocks
new water pump
new Optima yellow top battery
new rear main seal
new stock alternator
The following LC Engineering parts have also been professionally installed:
Dual friction clutch
New pilot & throwout bearing
30# flywheel (heavier than stock for better torque application)
Complete 2.25" header and exhaust system including high flow muffler and catalytic converter
K&N FIPK filter
flow matched fuel injectors
4mm overbore tapered throttle body
new (not rebuilt) performance head and cam
Balanced high volume oil pump
dual timing chain conversion with steel guides
Cyberdyne fuel mixture meter with Pro Tuning module
Here are a few custom fabricated items and misc. items.
Kongs rock sliders
Sonoran Steel custom bumper
Grant steering wheel
dash mat
Alpine stereo with three 8" subs in a custom box behind the seat and Alpine amplifiers running all speakers
synthetic fluids: oil (mobil 1 synthetic), diff fluid (redline heavy duty synthetic), transfer case fluid (redline heavy duty synthetic) and clutch fluid (redline mt90 synthetic)
bridgestone dueler a/t revo 31x10.5 tires on custom wheels, plus matching full-size spare
camper shell
rubber bed mat
full set of husky floor liner mats
replaced gauges (gas, speedometer, etc.) with an OEM set that has a tachometer and oil pressure gauge (the original set came without those, and still have original if you want it)
replaced shift knob with a leather one from a '98 4runner
replaced the stock headlights (that had sealed, non-replaceable bulbs) with Hella headlights and new, brighter bulbs
Items/Repairs needed:
AC compressor is frozen, so it may need replacing or rebuilding.
Asking $5,000, OBO. Come check it out and make me an offer... The truck is in great shape, still young for a Toyota, and I have gotten up to ~22 MPG with it. I have more pictures, just let me know and I can send them along. Thanks for looking!
new brakes
new belts
new hoses
new plugs
new plug wires
new cap & rotor
new thermostat
new O2 sensor
new knock sensor
new KYB shocks
new water pump
new rear main seal
K&N FIPK filter
Kongs rock sliders
dash mat
camper shell
rubber bed mat
