Cummins 6AT retrofit
Salem Oregon
I have a 82 Fj60, and a 6AT3.4 Cummins Diesel with a chev bell housing & motor mounts(from: LewDon). Does any one know if this set up will bolt rite in or do I have to come up with new mounts?. if so where do I get them or does anyone have details for making them?
you can use Advance Adapters motor mounts, though you have to cut them down. You will need 4" of lift _and_ need to trim the oil pan so it doesn't get crushed by the pumpkin. You will need the AA chevy bellhousing. You need something to produce vacuum (i used a Ford Vacuum pump of a late-80s diesel). it's a big project. good luck.
