For Sale Cullman Alabama Mercedes Om617 with nv4500 mated to fj60 tcase
Cullman al
Best way to reach me is by text 25662OO552
the engine came out of a wrecked 300d that had been sitting in a wrecker yard, I had all new gaskets on engine , new turbo and inj pump Was replaced with another used pump . Nv4500 had 60k miles and was from a gm 6.5 diesel. Tlc transfer was used and purchased from Facebook marketplace so I am not sure on the mileage . Adapters were from advanced adapters and 4x4 labs . Can start and hear run , will ship at your cost . $6000
Did you already swap the longer input shaft from a Dodge gas version in? Won’t be able to if that is the early 92-94 transmission woth the 6.34:1 first gear.
The nv4500 I chose was the later model. But I do have a set of axles with 4.10 gears of your after a lower range.
Im not after anything, just making sure that transmission will actually work with that 3-speed bellhousing/adapter setup for whoever buys.
Thanks for the concern , it’s all bolted up and been ran, no issues. All parts needed for this conversion can be bought from advanced adapters and 4x4 labs . Takes all of the guess work out if you decide to go that route. I traded my landcruiser before I got to install the set up and it was all original so new owner didn’t want this engine and set up
Can you provide guidance on the adapter? I would like to use the 3 speed bellhousing as your setup, but I'm not sure on the adapter plate that will fit from 4x4
