OK, thanks Graeme. I appreciate the advice, but others have said that the GT2860R - 707160-5 would work for what I need it for, so now I don't know. Maybe I just haven't provided enough info here to look at this turbo from my perspective, so I will do that and I hope that you and others can confirm that this turbo won't work. I really need to get this sorted out in the next couple weeks before I start fabricating adapter plates etc. I already have this turbo and got a smoking deal on it.
So here's the background and the math that I did and it seems as if this turbo fits really well on the compressor map.
I'm working on a fairly ambitious project. I have a Toyota Tacoma, but are swapping the V6 engine out with a 3.0 litre Toyota Turbo diesel. It is the 1KD-FTV (D-4D).
This intercooled motor makes 170 Hp at 3600 rpm (red line is 4400 rpm) and 260 ft/ lbs at 1600 - 3600 rpm (all the way through). To make this work for me, I am swapping out the electronic fuel injectors with mechanical injectors from a 4.2 litre Toyota turbo diesel 1HD-T (which would provide plenty of fuel) and the electronic fuel pump with a mechanical fuel pump from this motor's pre-decessor (1KZ-T). I will end up removing most of the other electronics as well and the motor will not be electronically controlled at all by an ECU. All the tuning will be done mechanically (old school). It has a 5 speed tranny.
As such, I also need to get rid of the electronic turbo and swap in a mechanical turbo, and while I'm at it, was thinking that I would also like to upgrade that turbo for more power. I am aiming for about a 25% increase in power (roughly 170 hp to 212 and 260 ft/lbs to 325) which is nothing extreme because guys are easily getting these figures with chips and other upgrades.
I've done the math on the Garrett website and came up with the following:
TurboByGarrett.com - Turbo Tech103
Airflow:
Wa=HP*A/F*BSFC/60
= 212*20*0.4/60
= 28.3 lbs/ min
Target Hp is 170*25% = 212
A/F Air/fuel ratio for this diesel is about 20:1
BSFC Brake specific fuel consumption is about 0.4
Manifold pressure:
Map= Wa*R*(460+T)/VE*N/2*Vd
= 28.3*639.6*560/0.97*4400/2*183
= 26.0 psi
R is the gas constant
T is the average intercooled air intake
VE Volumetric efficiency for the 4 valve engine
N is red line
Vd engine displacement in cu inches
Compressor discharge pressure:
P2c= Map+Ploss
= 26+2
= 28
Assume 2psi pressure loss between compressor and manifold (due to intercooler, etc)
P1C= Pamb- Ploss
= 14.7- 1.2
= 13.5
Pamb Average Air pressure in Calgary
Ploss Pressure loss due to eir filter, piping
Pressure ratio:
IIc = 28/13.5
= 2:1
I then looked at the compressor maps and found that the Pressure (28) and ratio (2) fit very well for the GT2860R - 707160-5. Map:
TurboByGarrett.com - Catalog
Looking at the maps for the GT25, it doesn't fit as well as the GT28.
I will likely just keep the stock air-to-air intercooler, or maybe go larger because I have lots of room in front of the radiator. My main goals are to have some good highway power for cruising around 120 km/h (75 mph) and my RPM would be around 2750 at this speed and also have some good low end torque plus good fuel economy. My truck runs on 37" tires, have a 10" lift on it and alot of extra weight, which is why the V6 was no good anymore, so I need lots of torgue at highway speeds. Not so much at lower speeds or for off roading and definately not for racing or speed.
Thank you very much for your help
