New for 2018 DOTM (Drawing of the month)
Each month we will post an Raffle item. Included will be the items description and how many tickets that will be available for the item. Once the amount of tickets are sold the raffle is closed. Strong interest can produce another raffle for the same item.
Raffle link click here ► CSC Raffle 002 ◄
Tickets offered - 25 total
Cost - $6 per ticket no limit
ODDS - 1 in 25 duh!
What you will do -
Log in to the raffle link above
Pick your lucky number/s (if not already taken)
Pay using PayPal
At each meeting will pick the lucky winning number using a state of the art bucket with numbered balls.
You do not need to be present to win.
All profits stay with CSC to help fund our Over-The-Top Parties
This month item is
- COYOTE Automatic Tire Deflators
These are 1st class Deflator and best in class with the most accurate adjustability.
COYOTE Deflactors info - https://www.coyoteents.com/deflators/
HOW THEY WORK
Coyote Automatic Tire Deflators are a spring loaded check valve with the ability to vary the spring pressure on the check valve via the Adjustment Cap. More spring pressure means a higher destination**, shut OFF pressure. Less spring pressure means a lower destination pressure. The Coyote Enterprise Automatic Tire Deflators are guaranteed to cover a destination pressure range of 4 to 56 PSI (CED456) and typically handle 3 to 65 PSI. and 5 to 45 PSI The two deflator, motorcycle set, the CED545, is guaranteed to cover 5 to 45 PSI and typically covers 4 to 50 PSI.
The Adjustment Cap setting is locked in place by the Lock Collar. Never use pinching tool like pliers or vice grips on either. This may distort the Main body, cause the deflator to malfunction. This voids the warranty. Use open end or crescent wrench-like tools to safely lock-in your destination pressure setting.
TEMPERATURE INCREASE ADJUSTMENTS
As tires warm up, the pressure increases. To pick up that increase from a cold morning air down, just screw the deflator back on the tire valve stem, pull, do not "snap" open, the Manual Start Ring and wait for it to shut OFF. Expect only a few seconds of air flow since this is typically a small pressure increase.
Coyote Automatic Tire Deflators come in two part numbers: a set of four deflators for 4WDs (CED456) and a set of two for motorcycles (CED545). Both include a carrying case and Quick set instructions.
* Abused, misused and lost parts not covered.
** DESTINATION PRESSURE: The pressure you have set where the deflators automatically turn OFF.
CAUTION:
Low tire pressure makes for unfamiliar vehicle handling. Never deflate your tires unless you have a way to reinflate them to the pressure recommended by your vehicle or tire manufacturer. Compressed air (gas) presents several hazards, so always use protective eyewear when setting or using your Coyote Automatic Tire Deflators. Never completely remove the Adjustment Cap from the Main Body while screwed on an inflated tire. This will shoot parts out of the deflator body and may result in serious injury.
ODDS - 1 in 25 duh!
What you will do -
Pay using PayPal
This month item is
- COYOTE Automatic Tire DeflatorsThese are 1st class Deflator and best in class with the most accurate adjustability.
HOW THEY WORK
CAUTION:
