Crawl Control install help
houston, tx
I finally got my CC and MTS installed this weekend. MTS went smooth and works great. Went to do the CC zero pint calibration with techstream and every time i do it i end up with a C120A and the VSC light on. I've probably did it 3 time with techstream and then did it with the paper clip all with the same result. Any advice?
did you press the on off button on the crawl control during the last stage of the techstream programming?
After a lot more reading last night i figured out that was my problem. Now its working.
Another quick question. Is it normal for the VSC light to blink when crawl is activated? Also in the low setting the vehicle was bucking quite a bit. Any ideas on that?
I don’t recall the vsc light blinking on mine.
The movement on the lowest speed is normal along with all the clicking noises. It goes away slightly if you increase the speed on crawl
Yeah i noticed that on the speed increase. In the medium and up range it was fine. I'll play with it some more. Hopefully the light blinking is normal or it goes away. I appreciate the help.
