Doing the timing belt and water pump since I believe my front crank seal is leaking. I have the crankshaft pulley off, timing belt etc. But I can't get the crankshaft timing pulley off to get to the seal? FSM calls for
SST, remove the timing pulley.
SST 09950-50013 (09951-05010, 09952-05010, 09953-05010, 09953-05020, 09954-05011,09954-05021) but of course I don't have the SST. I don't find any info. on any of the TB write-ups or after searching.
There are two threaded holes that I guess if I had the right bolts I could use the crank pulley removal tool to get it off. I tried to take the key out of the crank as well but no luck on that.
Anyone that has removed it let me know the steps and I assume I'll need to get some long bolts to pull it off.
Thanks.
Thanks.
