Hi guys. I’ve spent the last hour searching the forum looking for instructions on how to replace the front main seal on my 1985 FJ60 and did not find the answer I’m looking for. So here it is. When replacing the seal, do I need to remove the timing cover and therefore replace that gasket as well? The leak seems to only be on the seal but if I see a leak on the cover I will obviously replace the gasket as well.
Thank you.
Thank you.
