crash said:I agree with Christo. Definitely leave a 1/2 inch gap between the slider and bottom of body. The other issue I had was the sliders moving around on the frame, just a bit. A little adjusting with steel shims on the bottom of the u-bolts has helped, but maybe angling the u-bolts to take up the slack would solve this issue. (Lean the top to the rear, the bottom to the front to make the gap on the frame smaller.)
I built George's design sliders, using 1/8th thickness and a 2x6 rail. I wish I would have gone with the 3/16ths - maybe 1/4 inch on the outriggers. The sliders do flex into the body, just a bit. They have left 1/8 inch divots in the pinch welds - nothing to worry about yet.
1/2" of deflection over an 8" distance would be alot of flexural deflection.
I'd venture to say most of your deflection is due to movement in the connection to the frame rail (rotation of the mounting, possibly small rotatation in the frame, elongation of the U-bolts etc..). Seems like the key to minimizing movement here is the rigidity of the attachment to the frame rail. Tack welding as Slee suggested should help. I don't think thicker walled outriggers would really have helped that much.
Have you put a jack on it to confirm where the movement is occuring?
A bracket designed with 2 U-bolts might help, but from a rigidity standpoint this U-bolt setup seems less than ideal.
:beers:
Rookie2
