I was trying to do some maintenance on the truck yesterday and ran into a couple of problems I could use some help with.
1. I noticed some leaking where the rear drive shaft enters into the third member. I checked the FSM to see about replacing a gasket. I was wondering if I should just go ahead and replace the (pinion?) bearing and race while at it. I also noticed a lot of SST's to get that job done but don't have any.
2. There is a slight leak where the speedometer enters into the center diff. I thought I had remembered a thread about two small seals that could be replaced but couldn't find it in the search. If this is the case, how do you pull the cable?
3. I was going to rplace the fuel filter and noticed in the FSM I need to replace 4 gaskets, 2 on the in flow and 2 on the out. The filter came with 4 metal rings and was wondering if those are the correct gaskets rather than a rubber type.
4. My intent was to clean the trottle body. One of my concerns was loosing one of the bolts on the underside of the TB into the engine. Also, do I need to replace the gasket between the TB and the (don't know what its called) thing its bolted to.
The truck has 133,000 on the clock and unfortunately, I don't have a digital camera to provide pics. Thanks in advane for your help.
Buck
Buck
