Control arm bushing and bracket?
Wheaton, IL
Need help identifying what part this bushing and associated bracket are called. This is the drivers side. Ignore the white clip thats my attempt at a temp repair. The bracket and bolts sheared off and are roadside somewhere.
Passenger side is second picture and is fine.
...via IH8MUD app
Can't tell from your photo but is the frame side bracket still intact? FWIW I had the same bracket decide it had enough of my off-road escapades during a 2010 Utah explore. I suggest removing your ASB ASAP(!) or you seriously risk ripping a brake line (BTW: When this happens you lose all wheels worth of hydro brakes) similar to the carnage that occurs on an 80 with similar problem.
You'll need to fab a new bracket, assuming the frame side is not solid or missing, from angle and gussets that will get welded back in place.
edit: Looks like the Stabilizer Bar Bracket part #'s are: RH is 48824-60100 and LH is 48824-60110
Frame side bracket looks good. Appears the bolts all sheared, most likely happened over time and 4 if July wheeling finished it off.
When you say remove the ASB, excuse the ignorance, what is this referring to?
I did find the right page in the 2004 FSM thanks to your identifying this as the stabilizer bar.
...via IH8MUD app
That's your anti-sway bar bushing and mount. Do a search on those terms. This problem has been mentioned by a few people. Not totally uncommon in the rust belt.
Best of luck.
Thanks all, parts on order.
...via IH8MUD app
