Hi melias24,
Here are a few further notes and attachments which I dug out of the files and which may be of interest .....
As a starting point in finding a good HDJ100 with
1HD-FTE, it may be helpful to revisit the Model Codes designated by Toyota Motor Corporation Ltd and used worldwide for Toyota Landcruiser 100 series Wagons. The Model Code for any vehicle is found on a label affixed to the firewall in the engine bay. The Model Code helps to identify the specification of the vehicle. An example is attached.
The Engine type also is shown clearly on the same label affixed to the firewall in the engine bay.
When reviewing vehicles for purchase, it is useful to see this manufacturer’s label or request a photograph of it, so as to be aware of the vehicle specification when it was manufactured.
The Model Code does not help with accessories or options fitted by the manufacturer or a dealer. These may vary from market to market around the world. For example, in Australia AHC/TEMS was only fitted by Toyota to the final upgrade of the LC100 Landcruiser Sahara model manufactured from late 2005 to late 2006 (prior to introduction of the 200 series).
However, if the complete Vehicle Identification Number (VIN) is available, all factory-fitted options can be discovered.
The attachment “Landcruiser Model Line Up by Country” (Toyota document) gives an idea of the spread of specifications around the world.
To distinguish between engines ….
Earlier diesel LC80 vehicles were fitted with the
1HD-T engine which at least in Australia acquired a reputation, fairly or unfairly, for big end bearing problems. These are said to have been overcome in the subsequent
1HD-FT diesel engine. The point here is that if considering one of these older engines it is good idea to obtain input from people who have worked on them and who really know their stuff. There are quite a few old posts on IH8MUD and elsewhere concerning these engines.
In Australia around October 2000 (and maybe in other countries at similar dates), the 24-valve
1HD-FTE engine succeeded the 1HD-FT engine. It first became available on selected Landcruiser models from about the year 2000 with either 5 speed manual transmission or 4 speed auto transmission. The
1HD-FTE was matched to the 5 speed A750F auto transmission from about 2002. The non-turbo 1HZ engine also continued for a time, mainly in some versions of the HZJ105 Landcruisers.
The improvements in specifications and improved performance of the
1HD-FTE engine over the 1HD-FT engine are well summarised in the attachment “1HD-FTE Engine Improvements” (Toyota document).
Choice of 5 speed H151 manual transmission or the 5 speed A750F auto transmission is a matter of intended application and available servicing capabilties. Some people prefer the manual transmission for heavy 4WD work and/or as a matter of simplicity and personal preference. As can be seen below, the ratios in the auto transmission versions are a little taller. Nevertheless, it is fair to say that the 1HD-FTE engine matched with the A750F auto transmission, if both are well-maintained, enjoy a strong reputation in Australia.
The Toyota Landcruiser HDJ100 with
1HD-FTE turbodiesel and A750F five-speed auto transmission has the following ratios – see attached Specifications (Toyota documents):
First: 3.520:1
Second: 2.042:1
Third: 1.400:1
Fourth: 1.000:1
Fifth: 0.716:1
Reverse: 3.224:1
Final drive ratio: 3.909:1
The The Toyota Landcruiser HDJ100 with
1HD-FTE turbodiesel and H151 five-speed manual transmission has the following ratios -- see attached Specifications (Toyota documents):
First: 4.081:1
Second: 2.294:1
Third: 1.490:1
Fourth: 1.000:1
Fifth: 0.881:1
Reverse: 4.313:1
Final drive ratio: 4.101:1
In both manual transmission version and the auto transmission version:
Transfer gear ratio – LOW: 2.488:1
Transfer gear ratio – HIGH: 1.000:1
See more details at Toyota links within the following link:
AustralianCar.Reviews: #1 for Reviews and Used Car Valuations
Hope this background information helps inform the search!!
