Hi guys, i wonder if anyone can help me with a problem, i have a full floating rear axle with drum brakes and i want to check the bearings but 1 cone washer won't come out any ideas or solution to this f******ng problem
I usually gently beat around the outside of the housing with a BFH first.
Then I try beating on the stud with a brass drift.
I also have small flat head screwdiver that is filed to a point that I can tap into the slit in the washer.
Liberal doses of PB blaster in advance help too.
Lately I have been putting anti-sieze on the washers when I reinstall them. Haven't had to remove them since so I don't know effective that is.
I have never tried to double the studs, although I have had studs come out intead of the nut coming off. There is not really room to double nut is there?
f*************ck it won't come off it looks like it's fused with the axle shaft Put a piece of timber against the hub and hit it hard with a heavy hammer. I use a 2lb mash hammer. Have done this many times without damaging any hubs. Front and back. Best to use new studs, cones , washers and nuts. They are cheap and the nuts cop a flogging from rocks etc.f*************ck it won't come off it looks like it's fused with the axle shaft
nothing works , i'm out off ideas and don't want to buy new axle shaft, what about drilling the stud out??
drill a small hole and use the reverse tap thank you guys, hey Ron where do you order your cruiser parts?
