Compression
I always thought if you were within 10% your fine.
cool....
Just a thought for you - redo the compressions test but in reverse order. You may have had some cooling going on between when you did the first and the last cylinder. Funny enough, I have seen similar on mine, but when I warm it up again and redo the compression check (in reverse order) all of the cylinders are pretty much spot on at 140 or so (189k on motor). From the sounds of it - your motors tight, breath easy!
