Wanted Complete 1HD-T for FJ62 (3FE) Conversion (found)
Looking for a fairly low mileage (as low as I can find within reason) 1HD-T for my fall FJ62 engine swap project. I will be putting an H55F behind it so I guess I'm looking for the bellhousing too.
I found what I was looking for. Thank you for the responses.
id be willing to wager you wont be able to put an h55f behind it. However someone in the pacific nw had an h151f /bellhousing for sale not too long ago.
You might want to contact Torfab in Mukiliteo to see if he has anything laying around
H55F and split case are doable with the correct input shaft and bell housing.
Every 1Hx swap into a 60 series that I know of used the h55.
FYI, Cruiser Outfitters sells a brand new h55 with the correct 1HZ input shaft for just $2450...which is a stupid good deal considering that the input shaft alone is $300 not to mention the labor to take it apart and replace the gasser shaft. I bought one.
