I made a rear door table, thanks Nordic Cruiser for the idea
Also start to build storage boxes , I split it in the middle so I can still use one of the 3rd row seats. Not finish yet, need to make brackets to bolt it down and drawer handles. Will attach some drawer runners later, when finances are back to normal level.
I built a new bike rack,
I also made up an adaptor to move the spare wheel carrier 50mm up to accommodate bigger spare wheel.( awaiting delivery) One of the 25mm box section extends up to rear door window and it’s where I will attach the rear work light onto.
Power is fed from the rear power outlet down under the trim of the rear load area and through the flexible rubber coax that goes into rear door (electrics for rear washer, window heater). Drilled a hole into the back of spare wheel carrier, sealed it with silicon and feed the cable ( twin core flex 1.5mm)through and up into the box section to top.
I heard that people have problems with their rear power outlet not working,
Next on the “To Do” list is to wire a multi plug adaptor in the back into which the air compressor can be plugged and the camp fridge.
The last thing left to do was to extend the diff breather pipes.
The front axle breather I also extended and am now secure to the bulk head on the side of the big rubber grommet for the wiring loom. (has any one done the gear box and transfer box breathers?)
Now we can go and play in the water…….
