Color/Trim Codes for '97
Somewhere in NJ
Went to repaint my front bumper this weekend and was looking for the paint codes. Found the sticker on the DS door which said 1A5. I have a Desert Dune truck which is that light beige metallic color. The 1A5 I see at places like PaintScratch.com looks nothing like mine. The only search result I found for bumper paint codes was for a '99 100 series.
So I went to a paint shop and they too couldn't find any reference to the gray metallic color of the bumpers in their books. Even a body shop guy came out to look around my truck to see if they could spot something to tell what the color of the trim was...no luck.
Finally, I just grabbed the shops chip book and tried to compare the DuPont chips specified as Totota Land Cruiser bumper colors for '97 (of which to my surprise there were quite a few!) and came up with what was called Gray Metallic (surprise!) with a code of UCAA3.
Painted the bumper and side plastic wings, and it matched the original color very well; I am quite happy with the outcome. I was just wondering in retrospect if I just chose the right color, or if there is some other "official" color that I didn't get? Anyone else run into this? :cheers:
Yo Tom:
did you do any special prep for the plastic extensions?
did the metal and plastic ends both come out OK and the same?
E
No special prep, other than a good/thorough sanding on all parts. I was looking for some sort of special primer, but didn't see any, though if it was black, I would not have noticed it. The wife has developed a fondness for the DS side of the garage, so I'll probably be doing this job several more times before the 80 calls it quits.
DuPont sells a special additive for the clearcoat that should be used on flexible parts, so I added this stuff in. One effect of this stuff is that it lengthens the drying time quite a bit! Can't remember the code number for it, but you only use a little bit. I think I now have a lifetime supply :D
The metal and plastic bits look identical; can't see any difference, even in full sunlight. I'm thinking of doing the back bumper too just becuase..., but since it's in perfect shape, can't get to enthused about it.
