- Joined
- Sep 11, 2005
- Threads
- 184
- Messages
- 2,995
- Location
- Ashburn, Va
- Website
- www.landcruiserheaven.com
Ever since I bought my 97 40th anniversary she has had a knock in the engine. I have been amazed how reliable these engines are. In my home country (Colombia) there is a saying that says "Toyota es Toyota" or in English "Toyota is Toyota" It can be interpreted that Toyota is what it is the best 4x4 trucks point blank.
Last year around this time I moved to Va from FL. I had left the 80 back in St Petersburg along with a small shop that I had at the time. I bought the truck with a little over 152k on the clock. She now has 165k and has never skipped a beat. The knock is prevalent and the normal front main seal and oil pump cover leaks. But she has done over 10k with 2 round trips from Va to FL without a hitch.
Towards the end of last year I purchased from AU Ebay a Coilpacked 1FZ-FE from a 105 donor with a 5 speed ECU. I also sourced a complete H151F 5 speed swap from a donor in Colombia. My plans are to bring in the 105 engine and the 5 speed and do the swap on my US Spec 80.
My 80 Evolved - 1997 40th Anniversary v3.0
I want to document the swap as much as I can on this thread. For those that dont know why I would go as far as buying a 1FZ engine in AU vs the US, well let me shed some light on it.
There have been 3 generations of the 1FZ. The first one is the 1FZ-F which is a carburated engine running 190HP and 268 ft/lb TQ. Then came the 1FZ-FE which is the engine we have in our 80 series. It has 212HP with 275 ft/lb TQ. Then in 1998, Toyota came out with a new distributor-less 1FZ-FE producing 240hp and 300 ft/lb TQ. Since the engine came out in 98, it was never offered in the 80 series, it was offered in the 105 series and in VZ the 70 series. This is the engine I will be putting in my 80. Most parts are available in the US with the exception of the injection system.
I have sourced a lot of parts needed for my build in UAE and Japan. These will be here this week. In the meantime I started tearing down the engine.
Can't complain when it comes to a teardown on an engine stand. Got the head off in an hour.
I will try to document the differences between our 1FZ-FE and the holy grail of the 1FZ-FE.
I will also be doing the H151F 5 speed swap. I did the swap on my old 40th anniversary in Colombia and can only say that running 35's, stock gearing and a manual, was like driving a new truck. The 5 speed made a big difference in waking up this monster. I can only imagine how it would be with my current 80 with the updated HP and 33's.
Well with out further a due lets get this weeks update set.
