Code P2197
Fort Lauderdale
Anyone get this code on a 06-07? Popped up last night when driving home with a CEL and VSC lights. The code reads as
“P2197
Heated oxygen sensor (HO2S) 1, bank 2 - signal stuck lean Status: Confirmed”
Have not found many threads on here for this code. Seems to be most of the O2 sensor related codes are P0430
Should I start with replacing my upstream sensors entirely? Won’t be able to get into a shop until after the holiday if that is needed though.
“P2197
They're really easy to change yourself, unless the threads are corroded/frozen. Pretty cheap from Denso.
Yup. Was planning on replacing myself if that’s what it was. Just can’t seem to find the code reported here much and if that indeed is the issue.
