semlin
curmudgeon
- Thread starter
- #21
the vehicle has three noteworthy events i can think of that might be relevant
1. as per the below old thread link, the po "fixed" high rpm start up by adding a relay into the efi circuit in the main fuse block so that the ecu would have no power when ignition was off and would reset. i removed it and spliced the wires back to normal. i have looked very carefully at the repair i did and it seems sound.
https://forum.ih8mud.com/80-series-tech/531956-interesting-high-start-up-idle-fix.html
2. the main ground cable is too short. it was shortened a few months before this happened by the shop that switched my battery. they had to change the lug for the new terminal and i guess they cut all the slack out of it. the thing is now quite tight so i replaced it with a completely new ground cable even though it shows good continuity. then i realized that i needed the branch lines from the old one so i connected the old one as well at both ends. i can position the battery so there is no strain on the old cable for test purposes. it makes no difference.
3. the vehicle has a gentle front ender a few weeks before this happened. it damaged the bumper and valence. i can't see anywhere wire might be affected.
