Hey guys, I've been looking for a regulator for my co2 tank for some time now that will allow me to : fill tires, run air tools, and other various projects and air tools.
So far, most people that have a co2 setup, are running either a beverage regulator or a fixed 150psi balloon regulator or the such. The problem I see with both of these options is that, most beverage regs. have blow off valves set at around 50-60psi. That is too low psi to run air tools. The fixed regulator obviously cant be adjusted and 150 psi is arguably too high psi to run air tools (especially maybe a die grinder?) I know there are people that run air tools at this psi with no problems, but Id rather have options to run the air tools recommended psi.
Basically I found a good regulator from beveragefactory.com that I think will work perfect for me, so I wanted to relay this info to you guys. Here is the link:
http://www.beveragefactory.com/draf...essure_mixed_gas_double_gauge_regulator.shtml
The difference in this beverage regulator is the high blow off valve setting. You can adjust psi from 10 to 110 psi. and I think this would be perfect for our applications. One thing it doesn't list is it's CFM output. ? I think I'm going to purchase this regulator and see how it works out.
