SOLD CO: 2001 Lexus LX470 new AHC accumulators, T-belt/pump, + lots more
Year
2001
  1. LX470
Mileage
254650
Color
Gold
$9,900 located in Fort Collins CO
We bought this earlier in the year with the intention to make it the family hauler. A deal on a new minivan came up that we couldn't pass up so we've got to let this go. I've personally done an absolutely massive amount of work to this to get it family-ready. The body and frame is totally rust free except above the windshield, (see photos). It started life in Florida then has been in Colorado pretty much ever since. The truck has brand new accumulators and the AHC system works amazing and the rig rides like a magic carpet. New timing belt/water pump/TONS of other stuff in the list below. It has a pretty nice set of BFG all-terrains as well. The A/C is amazing and I installed a hands-free Bluetooth system so it's got the normal creature comforts. The retro GPS works great but probably hasn't been updated since 2008 so it won't have some of the newly-built roads in the database. Power mirrors, seats, windows, etc all work. I wouldn't hesitate to hop in and drive across the country. Clean CO title ready to go. VIN JTJHT00W513500876
List of work completed in the last year:
- New Dayco timing belt/water pump kit
- New OEM AHC accumulators and fluid flush
- Newly refurbished leather/woodgrain steering wheel
- BT45 Bluetooth adapter to work with stock stereo
- New radiator hoses, thermostat, and gasket
- New PCV valve and OEM hoses
- New oil, oil filter, fuel filter, air filter
- New serpentine belt
- Complete front hub rebuild with new knuckle seals, Koyo/Timken wheel bearings
- New CV axles
- New OEM front drive flanges
- New Delphi lower ball joints
- New Delphi upper control arms and ball joints
- New Delphi outer tie rod ends
- New front brake lines
- Front diff oil change
- Center diff oil change
- New power steering pressure, return hoses
- New power steering reservoir
- New front pads and rotors (Raybestos)
- New interstate battery
- Fresh alignment
- New poly steering rack bushings
- OEM oil cooler gaskets
- New front driver's window regulator and motor
- Replaced all burned out interior bulbs with LEDs
+ lots more from the previous owner
Issues that aren't a big deal but might want to be fixed:
-Front diff bushing clunk from R to D (very common issue with 100 series)
-CDL light stays on whether unlocked or locked (center diff lock still works perfectly) it's a switch on the transfer case that's hard to get to so I haven't worried about it. Replacement included
-Minor oil leak from PS front axle seal
Things I would not care about personally but I'll mention anyway:
-Missing cone/washer on 1 of the front drive flanges
-Roof rack cap missing
-Broken hub cap
-The vehicle was repainted a different color than original (gold vs grey) generally looks good
-Peeling clear coat on roof and some small rust bubbles above windshield (per above)
-Rattle in roof which I haven't pinned down
-Common 100 series/LX wind noise (windshield was replaced by previous owner, but it wasn't done correctly. I have a set of the correct OEM Toyota rivets that can be installed to fix this
-Front seat has some covers that aren't great but the seats still work
-Usual 2UZ exhaust tick
-Rear heater bypassed by previous owner
Your mail box is full. :) Just emailed you on CL, too, I think. Interested, not sure when I can get up your way, maybe next weekend?
