Clutch master cylinder (1963 '45 )?
Any sources for this? Having a hard time with SOR upgrade kit ($140.00), Any rebuild kits out there>? Can't be more than a few dollars worth of rubber parts for a rebuild kit.
thanks
the problem is usually in the bore, pitting and corrosion. somewhere in the 25 section there was mentioned a place that would use a stainless sleeve in the bore and rebuild the master.
you could swap out to later stuff.
How do I switch over to later stuff. Is there any write-ups on this? -thanks
There are write ups on here and pirate. Simple! There are tons of options. For goodness sakes I run a 86 MR2 booster with a 2000 Toyota Tacoma master in the factory hole of a 63 FJ45.
