Clutch - Adjustment needed?
Woodstock, GA
I have replaced my clutch as well as the clutch slave & master cylinder with SOR systems. The question is, how much should it be moving the clutch fork? I feel like it is not producing quite as much movement as the stock system used to before failure. This posible? Should I be adjusting it now so that I can actually see the clutch disk release or should the clutch disk always be under some pressure?
I need to be able to dis-engage the clutch so that I can get the trans back in (little plastic guide piece aint doling it).
Thanks for any input! :cheers:
