Hi all, the lights in my instrument cluster a absolutely woeful, I'd say at least half of them a blown or very dim, and I was wondering if they are easy to replace. If so, what model of bulb should I be buying?
lostmarbles said:Easy enough for me on my 1979..
Original dim bulbs:
Yip, then remove those silly stamped metal helmets (except in Australia where everything must have a helmet) which cover the cluster lights and your gauges will be so bright you'll need to use your dimmer switch.
ditch the bulbs and wrap the inside face of the cluster with EL Wire it will work like a brand new car
Thanks for the info guys! Can I just confirm that the bulbs I need a 194/T5 wedge bulbs? I don't' want to order the wrong parts...
Here's the two threads I was thinking about earlier Mark:..Isn't there a thread or sticky about ALL the bulbs for EVERY year here?
