I think that is pretty common, someone has probably stripped one of the caliper mounting holes in the knuckle,
there are a few fixes, the best, and quickest is to tap the hole (1/2-20 I THINK) do a search on this forum, I had the same thing happen to me, I wanted to pull the knuckle, weld it retap it etc to metric,,,,, you could drill it and put in a helicoil, but you got to pull the knuckle for that too,,, I found this solution and it works great!!!
for years I had even gone so far as to put in a 1/2 coarse thread bolt, and then jb weld it in place, that only works for a short time.
the 1/2 20 is just a hair bigger than what it is now which is a 12mm bolt in either 1.5 or 1.25 pitch,,
it may not be this at all
but that is my .02
good luck
