I've been reading up on the SOA conversion tech on here. I've held off posting some of the stupid questions and just spent all nite searching, lol, kinda sucks that everyone puts "SOA" in their sigs and a search results in a million hits!
I own and FJ62. My first concern is driveshaft length front and rear. I dont plan on doing a C&T right away. so i'm leaving the pinion angle where its at. i expect some vibration but this is not my daily drver. i just want to know if the shaft will work and not split apart on flex.
I plan on buying some cut and turned housing froms profits or some other such dealer and building new axles from there. thats hy the C&T isnt an immediate concern.
Second, Steering. Mine is a bit worn. could stand new and plan on doing all this with the axle, but money is tight and the rebuild will be a slow process. I'm looking at the hy steer arms from JT outfitters (local shop for me) i think that will keep my geometry correct. Is there a better option out there? anything that may solve my geometry issue and worn tie rod end problem at the same time?
Finally, clearanceing the crossmember. I've spent some time today under the truck and for the life of me, cannot see ANYTHING that is going to come in contact with he drive shaft. is there something i am not forseeing here ?
well, had a nother thought as i was typing that. U Bolts. i assume my stock ones will not longer work. how are you guys setting up the ubolts? are you reusing the u bolt pad/shock mounts?
