cleaning up old hex tile
The 50-yr-old hex tile in my bathroom didn't weather our remodeling project too well. Because this bathroom was one of the few rooms left untouched, it was used as something like a utility closet for the duration.
Now that the crew is gone, I can see this use didn't go over well with my old tile.
I've been using a razor blade to scrape off what looks like drips of stain or polyurethane (they refinished some woodwork in there, but apparently didn't use a dropcloth). But how to get the splotches of dripped grout off? That's not coming off with my blade. Also, the whole thing just looks really dingy and stained. It never looked perfect, but the imperfection was of the "gives it character" sort. Now the imperfection is of the "wow, do you ever clean your floor?" sort.
Any ideas?
__________________
Stairlift los angeles
custom gates los angeles
landscape design los angeles
electrician los angeles
The poly and paint can be removed with "Rapid Brush Cleaner". It's flammable and smells bad so ALL saftey equip (eye protection, rubber gloves, etc.) should be used. It's harsh stuff, but will dissolve any home grade finishes. Don't get it on any paint surfaces you don't want to remove.
Once the the paint is removed you can clean the tile with diluted white vinager..if that doesn't work go to the local tile supply house and get a product called "Bannish" it should get rid of any grout residule. All saftey equip. gets used this time too!
