- Location
- United States
Considering sell my current dual Tcase setup because I no longer want to do any wheeling that would require such a set up.
What you get is a 76 H42, AA Rockbox and a 76 4sp Tcase. This will net you about 100:1 crawl ratio. I purchased the nos Rockbox years ago and have not put hardly any miles on it. Very little offroad miles. The rockbox is noisy which appears to be a common theme with them. The 4sp case is twin sticked and has a case saver on it. I’m sure you would probably want the crossmember also. IIRC my rear driveshaft is my oem unit because I flipped the rear springs to make up for the additional length of the Rockbox. The front driveshaft I believe was a mash up of an FJ40 and FJ60 shaft??
No idea how much to ask so let’s start at $1250 obo
We will need to work together on timeframe and when I can get it removed.
Pickup or meeting up within some hours of Cincinnati would be possible. Shipping on your dime and some money for crating.
Curveball option if you’re mechanical but don’t have the money. You pull mine and install your H42 setup in my FJ40 is something that can be negotiated also.
