You have been on quite the odyssey here! Asking the original guy to look at it is probably a good bet, i'd want him to call me before trying any real fixes though beyond something simple.
Where were the wires loose? At the plug or going into the back of the sensor? Before you go crazy, I'd replace the one sensor, they're not too expensive. One bad sensor with a janky connection could cause intermittent issues.One has a somewhat loose wire. Could be the culprit.
One had play between the harness and the sensor. It wouldn’t be the sensor, which is 175 off brand and 450-500 OEM. Not running to spend that. Harness prob even more expensive.Where were the wires loose? At the plug or going into the back of the sensor? Before you go crazy, I'd replace the one sensor, they're not too expensive. One bad sensor with a janky connection could cause intermittent issues.
I agree. Seems like everyone is clueless on the matter. Frustrating.Also, to my knowledge any one sensor bad can trip P0500, and there's no way to tell which one, so the Toyota dealer saying it "Tripped all 4" makes no sense.
Those are cute@roadsalt if you feel like spending some money: '08-21 200 Series Toyota Land Cruiser SDHQ Built Billet ABS Guards - https://sdhqoffroad.com/products/08-21-toyota-200-series-land-cruiser-sdhq-built-billet-abs-guards
OEM Parts online aren't that bad, $225 per sensor, $125 or $145 for the harness from Olathe Toyota. Should be about the same from other reputable OEM sources online. Not nothing, but less than half what you were thinking.One had play between the harness and the sensor. It wouldn’t be the sensor, which is 175 off brand and 450-500 OEM. Not running to spend that. Harness prob even more expensive.
cheaper than a damaged sensor. good luck with your fixesThose are cute
O'Reilly sells the sensor for about $40. Not sure about the harness.One had play between the harness and the sensor. It wouldn’t be the sensor, which is 175 off brand and 450-500 OEM. Not running to spend that. Harness prob even more expensive.
The saga is over hopefully. The issue was solved. The mechanic mistakenly installed the sensors by the wrong wheels. So essentially, the car thought it was going in reverse. Or so I'm told. At any rate. I took it into toyota to clear the codes & give it a look over. Seems like I'm back in business, finally.
Yep I caught that, which is why I wrote ‘or so I’m told’. They f’d up something and didn’t want to tell me. Or it’ll come back on my next highway trip. Or they don’t even know what it’s was but after taking it apart and rebuilding they inadvertently fixed what they broke.What a story.
The story bothers me because—unless I’m having a midnight stroke—those sensors are side-specific but are also identical front and rear. So you physically can’t install the right-side sensor on the left-side of the vehicle (the connector would be facing in toward the knuckle), and it doesn’t matter if they’re swapped front to rear.
I wonder what really happened.
