SOLD Chevy 350 swap kit for fj 60 with ranger overdrive (2 Viewers)
Houston, Texas
This is everything you need (minus engine and motor mounts) to 350 swap your 60. I pulled this from my 60 running fine, i replaced it with an nv4500. The ranger leaks a small amount of gear oil, nothing major, I would re do the seals/gaskets since it’s already out. Everything works, it is a bit noisy but I believe that is normal for a ranger. No evidence of excessive play or vibration. This setup makes highway cruising a dream. Feel free to message or comment with questions. Cheers
Included is :
4 speed transmission from a 1982 Fj60.
Ranger overdrive: 27%
Crossmember
Ranger to 350 bell housing
Flywheel
Clutch disc
Throw out bearing
Slave cylinder mount bracket and slave cylinder (would recommend replacing) it’s a factory Fj60 unit.
asking $1500 obo. Located in Houston, tx
Willing to sell just the Ranger by itself? I don't need the transmission or crossmember, and I'm guessing the bellhousing and clutch bits add a lot to shipping.
I would prefer to move the whole setup but I will consider splitting it up if it doesn’t sell. Cheers
