That's the part that you bolt the steering wheel to in a 100% hydro-steer setup. Nothing new there.
Very dangerous and illegal for street use.
Well I can tell you with absolute certainty they are illegal in this territory. I sure wouldn't trust one at highway speeds.
Kinda like counting on a line-lok as an e-brake. No way it passes up here.
The legality of the unit for use in and of itself for street use falls under the "Failsafe Clause" within DOT requirements that should the hydraulic system fail for some reason and you loose pressure, there needs to be a means of a mechanical system to steer.
On those, they're purely hydraulic. For it to be a legal "steering assist" you'd need to tap it off of your steering box for it to be considered passing the "FailSafe Clause". This way you maintain your mechanical steering. There's info on how to do a steering box tap and route lines then from the system to the centering box all over the web, places like pirate4x4's bulletin board are one example.![]()
I keep hearing the exact same things about beadlocks.
But for some reason, nobody can provide the actual law..
