2013 LC, 77K miles, Bilstein 6112/5160
Went up to one of our state parks this weekend. Hit a few dirt roads going back and forth to a fishing spot. First leg on the road with windows down, no noise - second time on that road started hearing a metal-on-metal "clanking" noise coming from the left, rear wheel when the suspension is doing it's job. Sound also occurs when brakes are applied.
From that point on, on and off pavement, I now hear a metallic "CLANK" when hitting any significant surface bumps. Same happens when going over a speed bump at higher-than-idle speeds and occurs at the bottom of the down-travel.
I'm sure this could be a dozen different things. I haven't taken the wheel off yet. I've been using my hand brake quite a bit when parking since my shifter will give me a little "thunk" when there is movement after I shift to park. I don't know much about the hand brake components on these trucks (other than watching a video on adjustments using the star wheel), but maybe that's a possibility.
Thanks as always, guys.
