- Joined
- Feb 3, 2013
- Threads
- 55
- Messages
- 225
hi guys sorry if this is lengthy i hope at some point this information will be somewhat useful to someone else.
For the past few months ive been having a problem with my batteries keeping a charge. The pig runs fine once it starts but according to my voltage meter in the car ( as well as a multimeter) the voltage would slowly decline until the point that none of the electronics would work. however the engine still ran fine. it would run down to 10 volts but then pop back up again after a day or so.
figuring it was the alternator i took it down to autozone to have them test it. according to them it was well above spec. however i was dismayed to see that spec on it was 45 Amps. but whatever.
so after talking to someone who told me that autozone tests were worthless and recommended a second opinion i took it to a alternator rebuild shop and they tested it and said that while it was underpowered for my battery application it should have been adequate to keep the system charged properly and according to their tests it was operating fine.
with all this in mind i had picked up a 2F alternator at the swap meet and installed it. this did not fix my problem so i think its safe to assume that the problem was not with the alternator.
a small bit of luck i ran into the Optima rep ( i have two red tops that are less than a year old ) at my local autozone. he was nice enough to let me swap my batteries out for a new set. just in case they were the issue. but they ran down just as the old ones had. but it was nice to be able to rule them out.
My suspicions moved to the voltage regulator i took it apart and manually actuated the connections everything looked good and practically new inside but fearing that it may still be the culprit, i ordered another one. after some research i found the ACDelco E602A or Duralast VR729 appeared to be identical in circuit structure and pin outs and plug to the toyota.
installed this and started the piggy up and still only got 8 volts out of the alternator. revved the motor and ran it at 1.5 - 2k and still only 8 volts coming out of the alternator lug. ran it for a little while and sure enough the voltage slowly dropped. so i turned the car off.
the last thing i did was to check to make sure that i was getting a solid connection and that there were no wiring issues with any of the wires from the alternator to the voltage regulator all of the wires had solid continuity and ground and battery were solid as well.
so last night i got this idea....
i have an internally regulated 90 Amp alternator. that is waiting for install on my vortec. how hard would it be to adapt to mount into the place i took a look it the wiring diagram and all of the other wires ( except the one that provides power ) go to the voltage regulator. so this morning i gave it a quick fit and swapped the pulley and by god it fit. i had to shim the pivot bolt and use a different bolt on the bracket to secure the alternator ( i had some leftover ARP bolts for that ) so i got it in and started the car and i saw 14 volts for the first time in a very long time.
so i cant think of a reason that this might be a bad idea in the long term but if anyone has any input or words of warning i would appreciate them.
Poorly taken pictures to follow.
