Charging my AC
So I have everything in place (for the most part). Now I need to pull vacuum and add refrigerant. Do i need to add extra oil to the pump. This will be a R134 conversion. Is there a good write up on this?
The parts are all used from a wrecked 60. I had the under dash parts so I installed the under hood parts. I have the compressor mounted and all the lines will be hooked up tonight. I may have to take it to an AC shop since HF did not have the vacuum pump i needed.
